07 LT 5.3L Sudden no start/crank
J-Herkel
J-Herkel
It's not comms with the BCM, it's just the ignition/key start signal. 12V.
and the yellow wire is the starter relay trigger signal.. The BCM is in the middle.
Here's all I can come up with..
Ignition switch "START" -> 12V to BCM (PINK J1-14) [no power? bad ignition switch]
BCM -> 12V to Starter Motor Relay (YELLOW J4-21) [no power with GOOD ignition switch? maybe bad BCM]
Again, that 8V seems low to me.. It may not solve the problem, but I feel like you're skipping a step if you don't test those wires..
(Considering your lights all light up fine, no codes, jumping starter relay socket works, fuses good, new battery etc.)
Or find someone with a scanner that shows if the key is in the start position. (to rule out the ignition switch)
Thank you. I have a friend coming over tomorrow with an advanced scanner to see if it comes up with anything. I'll keep you updated and highly appreciate your help!
rockola1971
Indiana (formerly IL)
Scanner will be practically useless for this failure other than to see input and output state of BCM and PCM. Need to ohm that ground terminal in the relay socket to chassis ground to see if it is electrically connected and rule out a busted wire.
mikez71
Good luck, fingers crossed! Scanner should be able to tell you if the ignition if ECM/BCM are receiving the start signal.
Should be able to rule something out I'm sure..
rockola1971
Dont we already know that is happening since OP is getting 12v at the relay coil when key is turned to engine crank? No way for that to get there without PCM and BCM being happy.
mikez71
Initially I thought he was measuring one terminal that went from 12V to 8V back to 12V.
Now I see he has one constant 12V, and the other goes from 8V to 12V.
bad ground doesn't explain the 8V, which should normally be 0V I thought?
Ohming the coil ground is solid advice. It looks like that ground isn't really shared with anything but the rear washer.
(even a functioning rear washer doesn't mean the starter relay coil ground is good, possible broken wire as you both mention)
Ground Zone #5, Not sure where it's located exactly, somewhere on left front side of motor..
rockola1971
Im not really concerned with the 8v right now since it didnt happen when the key was in crank position. The 12v according to OP was there in crank position so thats all the relay coil needs for the hot side. Now im concerned about the ground side not being there which would explain his symptom of no crank. Wire could have gotten bit by a field mouse, pinched by something, damaged during a past repair or ?????? OP Jumping the contact side of the relay and engine cranks proves that side of it is all good. So he has a control side problem and it appears the 12v side of that relay coil is all good. I bet if he sticks a meter lead in the ground side socket and measure resistance to chassis ground that he will see way more than the 2 ohms or less that I would expect to be there. Those fuse boxes are pretty famous for corrosion underneath right where the wires come up to the fuse and relay socket terminals from underneath. The green crusties have been spotted there many times.
J-Herkel
J-Herkel
I took the entire Fuse box out yesterday, took it apart, removed all fuses and relays, removed the inside board and it was all clean. No corrosion. I will ohm the ground later when I get home. I'm praying it's something simple like a bad ignition switch but at this point, I have no clue anymore. The hardest part for me is the lack of symptoms. No crank/start and that's it. No thrown codes (to a regular scanner), no loss of power, good battery, good fuses, starter runs when jumped. I don't understand either why the relay is getting the 12v signal, along with the constant and you can jump it off its own ground terminal, yet it's not turning over the starter. When the starter is jumped via the relay, the engine turns over but doesn't fire. It just cranks. I'm assuming because I'm bypassing the other functions needed for it to operate like fuel and spark. It's hard for me to see a failed BCM or ECM without prior failure symptoms before ultimate failure. Who knows at this point. Hopefully this scanner later and help pin point something!
Bambiii
