07 up plug and play airbag rear system!!
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
make sure your rear upper mount looks like the 07 upper mount i did in first post becuase if not you will need to notch the frame to make it work
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
just did my buddys truck 3-4 rear drop last night. Pulled his springs on his 07 cadillac ext and sure enough same mounts as the trailblazers
992dr
Eastern N.C.
Do you have any pics of them installed?
Also at ride height and layed out?
Thanks
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
No sorry had it on my old phone but lost pics. There are a few guys i set up on here also but nobody put up pics.
they lay the axle on the frame
992dr
Eastern N.C.
Hi Tony,
How's the performance aspect of this swap?
I have a PPV and it handles quite well for this size vehicle, I'd like it to handle as good but hoping for better results. I guess a lot of it depends on the shocks used, correct?
One more for yah, what is the overall drop with these? 3/4"?
edit Mine already has a small drop. How much more would these bags drop it at ride height?
Thanks
Sam
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Hi Tony,
Thanks
Sam
The bags at ride height are about a 3-4 inch drop (depends on what you like) but the problem people do is they dont make them independent so lots of air trasfer which is bad for cornering.
if you want a good riding set up thats adjustable the tbss bags are nice
992dr
Eastern N.C.
Ok cool, I have a Pedders set up which by there site says its a 2" drop.
Another 1 to 2 inches would be nice, it would level it out.
I'd most certainly hook them up independently, like you said better results.
Would these effect towing/hauling?
Thanks again
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
2015 has the same upper mount. So you can bag a 2015 rear for about 350 bucks which includes bags/rear hardware kit/my bumpstops.
Goodinblack
I Like Tacos
Dirty South
Someone who has done this post some pictures....
Not seen one yet.
Is this a bad mod or what?
No pictures on how this looks when done.
wiser1
