08 Tahoe stalls a few seconds after remote start
ryanls1
Im new to this board but have read a bunch and have not seen anyone with this problem. I have a 08 tahoe that i bought a few months ago and have only had this problem maybe 6-8 times. I start the car with the remote start and a few seconds after the truck starts it makes a odd sound that i cant put my finger on and then dies. It sounds like it is happening when the ac compressor is kicking on. I start it back up and everything is fine. I have had no problems or sounds coming from the engine other than this starting issue. Any one have any ideas?
groundscr8pr
flaccid member
scarborough maine
what brand remote start?? it sound like its using voltage mode instead of tach to monitor when the engine is running. has the battery in the truck been replaced recently.
---------- Post added at 07:31 AM ---------- Previous post was at 07:29 AM ----------
could also be a prob with the ignition security interface. i would fine a local shop that installs the brand you have. let them check it out,
ryanls1
ryanls1
The remote start is factory. The truck is entirely stock other than some HID headlights, fog lights, and LED's elsewhere. Not sure on the battery life since i bought it used a few months ago.
GM Customer Service
Michigan
ryanls1,
I am sorry to hear that you’re experiencing issues with your vehicle. Did you take your vehicle into the dealership for a diagnosis? If so, what did they say?
Thank you!
Elizabeth, GM Customer Service
Cjr2
Cincinnati
My question is different, my remote starts the car but the AC isn't running until I put the key into the ignition. Sorry if I hijacked the tread.
GM Customer Service
Michigan
Cjr2,
What model year is your vehicle? I would like to take a look into this for you. Also, have you been to your dealership about this issue?
Thank you
Ben
PCB, FL
Mine does that every now and then and I find its because I didnt hold the button down long enough..
SmallXL
ryanls1,
Thank you!
I've had remote starting issues as well. '07 Yukon XL. Took it to the dealer and they could not duplicate the issue. The starter fires the truck up but dies quickly after (like the ignition is cut out). It's irregular -so it's difficult to diagnose.
GM Customer Service
Michigan
Smallxl,
I am sorry to hear you’re experiencing this issue with your Yukon XL. How often does this issue occur?
Thank you!
Woodman87
