Jerry Orldrive
Hey Guys! I posted this to green hybrid with no success so was hoping someone could help me here. Read below the HELP WILL BE RETURNED!
My 09 Tahoe hybrid has been having stalling, lurching and cylinder 7 misfires recently.
Rides very rough especially when idle or in reverse. Seems to be when the two mode is trying to shut down four cylinders or switching to hybrid mode. Also there is oil leaking out like crazy from underneath around the aux trans pump. the fuel pressure will go up and down while driving (I occasionally smell burning oil not gas.
the aux pump it seems to be leaking engine oil and it smells like engine oil and my mechanic said it was indeed. Auto shops flat out tell me to go to the dealers except my mechanic friend who is literally doing the research I am.
I can’t accept taking it to a dealer who will just redo all the **** I did above and charge me 10K. I am an orthopedic surgeon and will repay the best help with free phone injury consultation for friends or family!!
(I am a weekend warrior but a NOOB to hybrids). All the below was done with a very competent mechanic...the THIRD ONE stumped by the problem. II own several cars and rent them on TURO so I am DETERMINED to get to the bottom of this.
Codes shown:
P0300
(P0307, P0430 & P0455 but not anymore all these went away )
says “service hybrid system” on dash.
Things we’ve tried:
-We checked the fuel injectors and they are in good shape.
-we did engine oil and trans oil changes
-we shifted the car into M and the same exact shuttering and sounds occurred when the hood was popped in auto stop.
No
. I placed the vehicle in park and attached two videos of the symptoms.
-cleaned out mass airflow sensor and replaced
-air filter change
-new 12V battery
-Changed all the spark plugs (yup went in behind the passenger wheel under the splash guard)
-changed the coils.
-replaced throttle position sensor and throttle and cleaned with electric cleaner
-used cataclean and laquer thinner on the cat through gas tank (like Scotty said) and that cleared the P0455 and P0430
-drove around with mechanic who had attached his 7k obd reader. He only saw misfires and said it’s communication between the hybrid trans and engine and its getting confused but he isn’t 100%.
Is it a matter of cleaning the corrosion on the hybrid battery?
is it the aux trans pump?
Please help!!!
Codes shown:
P0300
Things we’ve tried:
No
-air filter change
-new 12V battery
-changed the coils.
Please help!!!
