09 Tahoe Oil Consumption issue solved
ezdaar
Chat Troll
Redneck central, Aka Houston
hmm, just had a thought. if moving the PCV from above t a pushrod solved it.
And theres probably no covers like that for 99-07.5,
Im thinking move the PCV on older VC's by filling or covering the OEM PCV hole and welding on a bung in new location..
Wonder if they would sell...?
jstutz101
Kankakee, Il
I suspect the oil going back into the intake is whats jazzing up the throttle bodies requiring them to be cleaned or replace so often. Good info!! Thanks!
HoS
Very interesting information.
Thanks for sharing.
jz57
How can I tell the current exist driver-side valve cover is an old or new version without removing it?
B
Bowtiebug
As far as I know you can't , they look identical from outside , the only noticeable difference is on inside .
My local dealer ran a Vin history for me to see if a dealer had updated it , you might try that .
Damien1990
Great post.
People should realize one thing However....
That part is is YEAR SPECIFIC.
Years have different parts number for the cover.
GM P/N 12570427 for 2007 - *2008
GM P/N 12642655 for 2009 - *2011.
So I can buy P/N 12642655 and put it on my 07 Engine?
B
Bowtiebug
No that part number is 09 up , parts department can check vin and get you correct part for your engine
Addicted
Warren PA
Great info. I dug through the receipts for the 07 I bought last fall. Luckily it has been updated, and they also replaced a deflector in the oil pan. ??
millz20
