120k maintenance tune up on 99 Denali
triumph.man
Hi guys!
I'm a new member here.
So I have a 99 Denali, and I went in for a quote on a 120k tune up.
They quoted me @ around $1000 dollars. I don't mind paying this, if this is an avg quote, but at the same time I'm not sure if they are trying to rip me off or what. I had always thought tune ups run around 400-500.
Can anyone help, and also, what should be included in this tune up.
Thanks!
---------- Post added at 12:22 PM ---------- Previous post was at 11:20 AM ----------
anyone?
sparg93
Expedition Tahoe
NJ
Did they say what they were including in the tuneup and the manufacturer of the parts they will use? (i.e. AC Delco)
As an example - if they are only changing the air filter ($20), plugs ($50), wires ($50), rotor ($11), cap ($50), fuel filter ($10), greased bearings (<$5), MAF cleaned (<$5) I wouldn't pay them anywhere near $1000...if that was all they included, it seems awfully expensive to me.
However, if they are also going to service the rear diff, transmission, and transfer cases with new fluids/gaskets/filters...then it may be worth it b/c of the time involved and the piece of mind knowing the tougher items were completed by a professional.
Maybe someone on here has had a complete maintenance performed on their SUV by a shop/dealer and can chime in.
If you're interested to do this yourself, maintenance on these SUV's is pretty simple...there are how-to videos on-line and if you ask for a list of items to purchase, I can easily post the manuf #'s and an inexpensive place to purchase them. Plus, with all the money you save, you can buy all the tools you need and have $100s left over!! (plus the satisfaction of your own tune-up)
I've personally never brought my car in for these services, so only take my opinion with a grain of salt.
Hope this helps :)
---------- Post added at 01:34 PM ---------- Previous post was at 01:31 PM ----------
Quick side note:
Unless your vehicle has had regular service intervals on your transmission, DO NOT FLUSH YOUR TRANMISSION FLUID!!!
Even with regular service, most people still only have the trans drained, new filter and have it filled...flushing it may cause your trans to slip.
T
triumph.man
Yes, the have told me that they will use all AC Delco parts.
What should the typical 120k maintance be?
sparg93
Expedition Tahoe
NJ
Did they say what you were going to receive as part of this maintenance package? (i.e. what services they were going to perform)
T
triumph.man
Thanks! I will get back to you after I get that quote.
BTW i'm in NJ where labor rates are @ $85/hr
sparg93
Expedition Tahoe
NJ
No kidding - so am I! (Monmouth County)
There is a BlackBear Performance tune taking place in Old Bridge June 10-12. If you have some time, you should def stop by as there will be about 30 members of this forum there.
Check out Blackbear's vendor page on the forum and you will see details about the event.
To your original point, even in NJ, $1000 is a lot of money if they are only doing a basic tune-up on a GM vehicle!! But if they are doing a complete job and including tranny, front and rear it might be worth it.
T
triumph.man
Thanks everyone for ur replies. Here's the breakdown of the services.
So here's the part breakdown with the part cost/labor cost
Distributor cap - 78/43
Ignition cable set - 213/120
Spark plug - 120/119
Ignition rotor - 18/43
Air filter element - 43/34
Fuel filter - 21/43
All parts are ac delco and labor @ 85/hr
Do these prices seem reasonable?
Reason I'm doing this tuneup is bc I'm getting a misfire
sparg93
Expedition Tahoe
NJ
Distributor cap - 78/43 $50
Ignition cable set - 213/120 $50
Spark plug - 120/119 $50
Ignition rotor - 18/43 $11
Air filter element - 43/34 $20
Fuel filter - 21/43 $9
In red are the actual prices if you purchase from retailers. Also, it takes 1 min and 35 seconds to replace the air filter element...not sure why they are quoting you 34min, or over $40 to put in an air filter!!!
Go to advanceauto.com, plug in your vehicle's info, select "Replacement Parts" and then click on tune-up...
http://shop.advanceautoparts.com/we...o&selectedPartNumber=&qty=1&ship2HomeClicked=
All the AC Delco parts will listed there for you. Plug in the 15% discount coupon and you will get 15% off plus a $50 coupon b/c you're going to spend over $100.
No need for a new coil unless you are having starting problems.
For AC Delco spark plug wires and the gas filter, buy them on Amazon from the AC Delco rep...they are $50 and $10 respectively...on autozone they are ridiculously overpriced for those two items.
Then take that $50 coupon and buy replacement fluids...IMO fluids are rarely discounted and if spend $100, use your coupon and you'll get your next purchase for $50. I just did a tune-up a few wks ago and this is what I did.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
It called part up charge that is one way a shop makes a profit. What a ripoff the dealer would sell you spark cable set for about $100 yet the shop wants $200.
---------- Post added at 04:32 PM ---------- Previous post was at 04:28 PM ----------
They are also using time estimate from the vehicle manufacturer which includes thing like opening and closing your hood, prep, packing box removal, retrieving from stock and such.
meow
