TruckBoss223
Isnt that the rcx ? everything else is knuckles. the old DC 6.5 would have been perfect should have bought it when i wanted to 12 years ago
I dont think you understand what i was getting at. All i want is 6" of lift. I was told by RCX guy that when you install the lift kit your going to have to crank a little to get the 6". I dont want to crank. I want the RCX lift since the wheel track stays the same with the stock geometry and leaving it perfectly level.
I DO NOT want a knuckle lift system. so what my plan was is this
if the RXC 6" lift is technically 4-5 inches with some cranking
then add the 2" or 1.5" torsion keys
that will equal 6" of true lift with nothing cranked and everything in stock geometry except the driveshafts of course.
I am not trying to go higher than 6"
ok ill pm you with my number right before i order it. just waiting for the truck to get back from the exhaust shop then the body shop
Simply brilliant. Man i just looked it up.. 1700$ for it. : (
If you engaged your 4wd on the street over 35mph with 8" of lift in the front, you are going to have a nasty vibration running the OEM front driveshaft. Low speed 4wd you won't notice it but I'd bet you've got a pretty steep angle on that joint.
Also, the various lift manufacturers have differences in their systems...so just b/c it works for one lift, doesn't mean it will work for another. As an example, the RCX is NOT a true 6" lift, you have to crank your TB's to grab that extra height. If you crank an RCX lift that high, you will destroy your front end.
As the last poster mentioned, with the amount of $$ spent on IFS lifts, a SAS becomes a really nice option. However, unless you have fab skill and are really comfortable with custom work, shops charge huge $$ to SAS a truck and a properly built front axle with cost you a ton of money if you can't do it yourself.
The zone offroad is not a knuckle liftIsnt that the rcx ? everything else is knuckles. the old DC 6.5 would have been perfect should have bought it when i wanted to 12 years ago
I don't know what your having done at the exhaust shop, but if you put any kind of lift you will most likely have to have the front crossover pipe move because of the front driveshaft.ok ill pm you with my number right before i order it. just waiting for the truck to get back from the exhaust shop then the body shop
Nope never had a problem with it, ran it like that for over a year. It's a true 6" drop, just like the old dick cepek which was a 6.5 drop, seen people with it cranked over 8". So i've read the rough country is only a 5'' drop with crank to get 6'', so my around 1.5" over my 6" drop is to much Ok...
Great info Julian on the different lift types.
The DC lift is a REALLY nice lift as you pointed out TT...Bowtie runs one and even though it's a beast to install and pricey, the engineering is incredible.
Increasing your driveline angle by lowering the front differential 6" is going to cause a vibration, more noticeable the faster you drive. For the sake of a recommendation for a new four wheeler, to properly lift his truck, he needs the new front driveshaft.
Also, in my personal opinion, you can[ crank up to 2" and be relatively safe, but 2"+ cranking is a recipe for worn out parts and more time fixing the truck then playing in the mud
I don't mean to simply be disagreeable on your comments!
Nah it's good man, I get what you are saying. I agree about the 2" crank,I'm really closer to 1.5" on my crank. The thing with autotrac is that the driveshaft spins regardless if your in 2wd or 4wd and I never experienced any drive line vibration. The only thing i figure that differs with the zone, is that it rotates the front diff slightly, giving less of an angle on the drive shaft. Was just helping with what I went thru, besides my truck now has a np241 in it because my 246 developed a hole from the pump rubbing, stupid autocrap lol.
