1998 yukon Mystery p0300 and rough idle still
OR VietVet
Multnomah Falls
Military
Willamette Valley
Side to side play? If spins freely and the side to side play is tiny tiny, then likely ok but if is original, like @east302 says, I would replace while is out and dont cheap on it. If you have a GM cam sensor, get a reman dist without sensor, if not, get a reman with new cam sensor and may even come with cap and rotor. Discolored teeth? First I heard of that. Drive gear?
O
OilBurner2003
It does have a little bit of side play, also, when it spins there is a very slight hesitation and a light clicking noise. I think it’s a GM sensor, no clue.
OR VietVet
Multnomah Falls
Military
Willamette Valley
When you spin without cam sensor in it, does it make the noise? That shaft should spin freely, no hang ups that can get worse with engine heat and no clicking at all.
OR VietVet
Multnomah Falls
Military
Willamette Valley
That hesitation and clicking noise could be the shaft bearing and when gets engine heat in it, it can swell and get worse. Hell, its not my money, get a new or reman dist assembly, cam sensor, cap and rotor
O
OilBurner2003
Might as well at this point! If I go any further I’m gonna start doing leak down tests. Well, I’m gonna get started looking for a kit. I suppose I can only resume when I get this part installed with new cap and rotor as well. You gentleman have been a fantastic help so far!
east302
Mississippi
I’d suggest reusing your cap and rotor if they’re new and Delco parts.
When were the lower intake gaskets last done? Slightly higher misfire count at #2 is in the right spot for a leak, but your counts are on both banks which should mean something that would cause a widespread issue. Or both gaskets being bad. And there are no coolant leaks at the intake/block seams or along the sides under the valve cover edge?
Knock on wood, never had the joy of a P0300.
O
OilBurner2003
Well sir, lower intake gaskets have never been done on this engine since it was swapped, I think 11 years ago now. I have no doubt they’re in crappy condition. I’ve asked about them in the past but I’ve never had hard coolant or noticeable coolant loss, or overheating.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Remember, I said, smoke test is not always gonna show problems. I know and so does @east302, that sometimes you cant see what is right in front of you. If, a big if, you are gonna keep rig, then fix even something that is not the current problem. While you are in there and can afford it and gonna keep, do it so you dont have to guess later. The rig has time on it but is worth fixing, when it meets your needs and is paid for. Think of what you can do with just a portion of what newer rigs cost. Use quality parts and take the time to do it right.
O
OilBurner2003
Probably a good idea to do the gaskets anyway, that way it can be ruled out regardless even if the distributor fixed my issues.
alvey09
