2/3 drop kit on a 2018 PPV?
Ghost10
I've had good service from Diablo and Lenox. I've probably seen those and just assumed they were for masonry without actually reading the labels.
I use Lenox stuff at work never had any issues but Diablo has been ️ for me
17Betty
the only reason you have to cut the lower ball joint threads is if you're running a certain size wheel or smaller. also be prepared to cut the upper control arm threads off as well to clear the axel if your new ride is four wheel drive.
MrMonte
On my 2018 Yukon I cut the upper balljoint to clear the front axle. Used a dremel & tool less than 1 min. Didn't have to touch the lower but I have factory 22s
antennabob
