2 door tahoe/blazer/yukon if you got one show it off
ProCompTahoe, what did you do to upgrade that 4L60E? I'm currently running a 32 inch E range tire, but if I decide to lift and add some more tire, I have no doubt the tranny's gonna need something. Of course, it's gonna need gears, too, since I've got 3.42s now.
I seem to have an innate capability to choose trucks with crappy gearboxes. My last truck was a Dodge 4x4 that last 60K miles before the 360 wrung the transmission out from under it.
96ProCompTahoe
IN
i had everything listed out on the other computer but it ate the hard drive. had a friend rebuild it with everything i could find. hardened shafts, 5 gear planetaries, heavy duty clutch packs, etc. supposed to handle waaay more than the stock engine could ever throw at it.
4.88's FTW!
What kind of gas mileage do you see with the 35s? I'm getting 15-16, but I think if I had 3.73s or 4.10s, I'd do a little better.
96ProCompTahoe
IN
usually 12-14 mixed driving. dips down below 10 if its been a bad week. sucks but could be worse
Whippled2dr
Stock
SF Bay Area
whippled---what size tires and wheels did you wind up going with? What offset did you use? It looks like you have dropped it too, is that recent? Did you ever put the 6.0 in?
Wheels are 20"x8.5" Boss 330 in silver. Offset is +20mm I believe. I've always had a drop. I use to have the Belltech 4x4 drop kit (drop keys and drop leafs). Now I have a modified DJM 4dr tahoe shackle/hanger kit in the rear and the same belltech keys up front. Total drop is about 2/4 maybe a tad more.
The 6.0L is still on the stand, hopefully I can find some time in October to install it.
RSTahoe99
Rowlett, TX
Any issues rubbing? What tire size?
ft541
mY 2dR HoE
Here's my hoe its a 95 on some 22's i think it has been lowered not sure just got it not long ago but i want to clean it up what u guys think should i take off the chrome trim n modlings? and the side steps???/ i dunno give me some ideas
96ProCompTahoe
IN
loose the moldings, wheel well trim and the steps. look much cleaner.
Loose_Gasket
