not really a whole lot of other possibilities, if it was the Security module it would attempt to start and then die a second later and the security light would be flashing at you but it doesn't sound like that is the problem.
ignition switch could be bad, but I think you could confirm that by checking to see if the starter solenoid is getting power when you turn it to start.
just for ***** & giggles have you checked your fuses?
