I had not tested the 12 v wire to the starter while cranking. It is 12.x volts when the power is on but this wire also drops down to 6.x volts when cranking. So both wires to the starter are not getting 12 volts. I tested the voltage at the battery while cranking and i'm getting 6-7 volts. Is this kind of voltage drop right at the battery while cranking normal? I just bought this battery yesterday.
