rockola1971
Not referring to a vbelt or serpentine belt. Referring to the rubber belt sandwiched in between the inner and outer portion of the harmonic balancer. You stick a severely out of a balance hunk of metal (What happens when the belt slips) onto the end of a crank and that crank will be stressed across its longitude and at the bearings. Nothing good will become of it.I'm not following you. Are you saying that a belt slipping or falling off can cause a crankshaft on the LS engines to snap? I don't really see that happening under regular driving conditions.
On these engines the crankshafts are internally balanced to the rotating assembly. The harmonic balancer is not to balance the engine, only dampens small vibrations (or harmonics). That's why is not keyed in. The flexplate is not indexed either like some of the older engines or had a counterweight on them. Accessories are not balancing the engine either, and are usually only dragging down a small percentage of the engine power.
A lot of the 70s and 80s engines had gray cast iron cranks that were very brittle and these are times before advanced computer modeling such as Finite Element Analysis was developed. Coupled that with externally balanced design, I can see a belt coming off causing issues on those engines.
Edit: typed this last night and now see @2006Tahoe2WD Seems like we are saying the same thing about the harmonic balancer...
Troubleshooting Harmonic Balancers • The Original Fluidampr
10 signs of stock elastomeric harmonic balancer wear. Learn why they wear down and when to upgrade to a quality viscous type harmonic balancer.
