2003 Yukon General Maintenance
W
Wings720
Doing all new front brakes (07 calipers and rotors)
Need to replace hydro boost and master cylinder as well? Any upgrade recommendations?
Also should I mess with the tranny filter and fluid? Or let it be? Been reading these grenade at 160k. I’m at 141k. I repaired the leak from the lines but that’s it so far as tranny stuff goes.
nonickatall
Germany
I say that it make no sens to replace parts which are not ready for overhaul. So why replace hydro boost and master cylinder, when you have no issues with them?
You should very urgently change the transmission fluid because that is necessary that your unit will last long. I personally think that it's not so important to change the the tranny filter because it is more a filter that is of a fleece on the inside and is intended to filter chunks out of the oil if pieces of metal break off somewhere. It doesn't filter out suspended matter like an oil filter. That's why, in my opinion, it's best to disconnect the line at the front of the oil cooler and replace the oil above it. Firstly, you then get more oil out of the system, secondly, it is much less problematic than unscrewing the oil pan and changing the filter.
And then you still have to flush it anyway, because you only ever get around a third of the oil out of an automatic transmission through the oil pan.
06Z71TAHOE
