2004 6.0 NV4500 Tahoe
pwtr02ss
Tennessee
got a friend over in st pete/largo i usually stay with over that way...been wanting to do some more stuff at bradenton track (streetcartakeover this weekend) im just beat....the drive over sucks usually
I’ll let you both know when I’m gonna be that way. Cape Canaveral will on the list as well, maybe the keys? No time soon, but sometime in the next year.
no RTT with gen 4 stuff
on the older stuff i think you had to select which tables you wanted to use for the RTT
May be something Dan can check out then.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Well my changes aren't seeming to work. There must be another table I'm missing that controls fueling below 1200rpm. I can't see it needing the same fuel at 1,200 rpm no throttle as it does at nearly 6,000 and WOT.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
why is your engine running at 400 rpm?
check for exhaust leaks
I don't believe there's any major leak, certainly don't hear or smell one but I suppose a looksie wouldn't hurt. The dip below 800s is from startup and when I engage the clutch and the rpm dips down, this is dramatized by the lean condition making it want to stall and jerk violently. I'm fairly certain anything under 800 registers as 400. Let me see how many counts those cells hit tho.
DT360
