2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Yeah I was planning on saving a couple copies of the BB tune thst I download from the PCM, on a couple different computers. You know, just in case something happens to one. :rockit:
Plus I’ll keep the Autocal for the near future and I have copies of the tune in EFI Live format too so I can always load it from that.
When your HPT comes in it should come with a flash drive that has the programs on it, I used that for a long time as a backup for all my tunes.
Finding the correct tables to log and getting them set up seem to be something I can't wrap my mind around. When I get ready to log in a serious manor, I'll be asking some questions. Probably very simple, I'm just brain locked at that point.
Finding what to log is definitely the difficult part but guys like Goat rope break it down pretty easy, when you get ready to do stuff I can send you some scanner setups to make it a little easier. However, I suggest watching videos on how to do it from scratch so you can advance your knowledge of how the program works.
So the truck did the weird lean mode again at startup this morning, let it idle I minute or so and it cleared up. Maybe I need to look at something to do with startup fueling, also need to look at spark during the event because it feels like it's getting too much spark.
pwtr02ss
Tennessee
That would be great.
As previously mentioned, I've watched a bunch of his videos and he is great. I just get confused when I'm following along perfectly fine and then he jumps to a Gen 3 tune. Like, its much different. Annnd, I was trying to tune narrow band...you know, because I didn't wanna mess with wiring and wideband and putting the extra hole in my exhaust. Then, another dude on here said you take the rear o2 out and use that, even with catalytic convertor so now, I'm going to go that route...
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Behind a cat? That sounds not right but then again so many people tune with a sniffer up the tailpipe so idk, I've seen so many conflicting things on that.
I understand gen 4 is totally different, you really have to start small, like super small. Most videos out there assume you know too much and use big scary words, I've had to stop one video and google wtf he meant and then restart days later lol.
I think if I were you id look into a tailpipe clamp sniffer set up over pulling an O2 sensor, that's still way too much work every time you want to log data. The easier you can make data logging the more likely you are to do it.
pwtr02ss
Tennessee
Thats what I keep seeing so I'm confused too. The rear o2 slot would be perfect though:( Just turn off the rears and leave it until I"m satisfied then turn it back on
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I guess there would be no real downside I can see to turning the rear O2s off unless they need cat overtemp fueling. I kinda doubt they get overtemped tho.
Mine have been turned off since I installed headers. I plugged one bungholio and put the wideband in the other. Not sure if that’s kosher but it seems to work fine.
SkyWalk3r
