2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I’ve been thinking about what intake and TB I can upgrade to on my ‘03 5.3 Flex. The TBSS and NNBS are the same? Didn’t realize I’d have to get a x-link harness. That makes the idea a lot less appealing. [emoji53]
From my research yes the NNBS and TBSS are the same but I'm not a pro on the subject. I do know that an Xlink is required for any throttle body that is 6 pin being installed on a truck that was originally 8 pin.
I don't know how much power is really gained as I never did a NBS and 78mm TB swap to a TBSS with 90mm for back to back testing. However every article I've seen praises the TBSS combo.
The NBS 6.0 and 5.3 TB are 80 mm and good to about 500 HP and a 90mm isn’t going to do a thing for a NA engine. Even with my blower I don’t need a bigger TB, with a smaller pulley I ran out of injectors( again) but not TB.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I agree the 90mm is overkill for an NA motor. Only put it in because I had it and wanted to solve the reduced engine power BS that the 87mm was causing (I think). But one could argue "why did gm put a 90mm on the vette if it wasn't going to make more power?".
I do believe that a bigger TB makes a difference on boosted applications! I assume it would let the blower suck air easier and likely increase boost. May not be noticable at low boost levels or even with a butt dyno but every bit helps. It may also have a minor effect on IAT which are always a struggle with hot air intakes.
But again the gains are probably not financially worth it. That's exactly why I don't have a giant 102mm or whatever the big one out now is. Also my experience with the LS2 is pure 100% reliability even at 19psi.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Did some pulls on my way to work today and as expected I see absolutely no change on the AFR gauge or in the butt dyno. I remember reading somewhere that the TBSS/NNBS intakes are designed for optimum flow with the 87mm. Can't find the article though pretty sure it was a Richarld Holdner article.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I'm sad to announce the death of a 10 year friend. Haven't done an autopsy yet but I'm assuming COVID-19 got him. Was driving across town pushing 75-80 with music playing pretty loud and of course the bass knob turned up. Suddenly the deep clear lows turned to some terrible flapping noise and I knew he was dead.
Turns out 10 years of abuse is about the life expectancy of a JLW3-V2. I've no joke had it since 2010/2011 and had it in at least 9 vehicles many of which it just rolled around the trunk due to not being strapped in. There no visible damage but when I push the cone in I can hear a bad noise.
Heres some inside pics of the custom box.
View attachment 251093 View attachment 251094 View attachment 251095
RIP:(
rgosart
10 years is not bad at all! I have had my 10W3V3 for 6 years and I bought a 12W3 for the Tahoe in 2019. Never had any issues with my JL stuff.
The Tahoe needs a set of components up front. It has been on the list, but not a real high priority because I have some decent 6.5" Rockfords.
YukonLover
