2004 6.0 NV4500 Tahoe
Onebad1983
Resident Country Dumbass
Do you know what factory option had to be chosen for an SUV to get hydroboost? Mine is very base model so I thought it was weird that it had it.
Maybe it was added by a previous owner.
I have no clue if it was added by a previous owner. This thing was supposedly owned by an older couple since new so I have no clue
Sam Harris
Texas
Looks like it might be: JM3, JM5, or JM7..?
Looking at the RPO codes, looks like JM7 is promising:
JM7 12130 P BRB M BOOSTER BRAKE, HYD, HI PERFORMANCE
There are many more I just found. I’m not sure how to narrow it down. Do you have your RPO list?
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
RPOs, good thought! I'll have to check those when I get to my computer tomorrow.
Installed the 4Hi circuit board which is so easy a cave man could do it. Also needed to do a tire rotation so I also threw on some 1/4 wheel spacers. The inner sidewall on the 285s rub the rear inner fender just a tad and I think that's cured now. Also at full lock the fronts rubbed somewhere. Never found rub marks but I could feel it.
I'm not a big fan of wheel spacers and I've never run the cheap kind that's just a disk with holes in it like a giant washer. Well never until now. Got them torqued to spec no problem and survived a test drive up to 80mph with no vibrations. Came home and re-torqued them which none were loose so that's good.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I think its JH2 BRAKE HYD POWER, DISC/DISC, 7,200 LBS
Its the only one that seems to make sense out of my RPO codes. Anyone else have hydro and mind posting their RPOs?
I'm just curious to know what package the hydroboost was included with since mine is so base.
Mike4400
