2005 starter wiring diagram/schematic
HammerMMI
I am only getting 1.0 vdc on terminal "S" in the start position. Solenoid clicks but won't engage. I have replaced the battery, ignition switch, starter and ignition relay, and starter, ground connections cleaned. Same problem. Has anyone solved a problem like this?
Yes, many have solved it.
Try doing a voltage drop test. You may have a bad positive or negative cable, or a bad engine-body ground.
There are also ways to bypass the starter relay; g00gle it.
SSVTahoe16
