Bummer. I used the below air impact wrench with the proper impact socket and a cheap Harbor Freight air compressor. Came off like it was buttah. No flywheel tool or strap wrench needed.Update - well saying the removal of the cam sensor was a PIA is putting it mildly! I drilled a larger hole, screwed a masonry lag bolt into and filled with JB epoxy let set up for 48 hours. Then tried to extract it, used a large pry bar and block of 2x4 as a base for the pry bar. The pressure I was able to put on it with that process did not make any difference, that son of gun will not come out.
I am not down to removing the timing cover to get it out. With the that in mind, what is the best way to hold the HB to remove the bolt? I was going to use a large pair of vise-grips slipped through the opening in the back and up against the AC bracket and use my air impact driver to remove the bolt.
1/2 in. Composite Air Impact Wrench, Twin Hammer, 1190 ft. lbs., Green
Amazing deals on this 1/2In Composite Air Impact Wrench Green at Harbor Freight. Quality tools & low prices.
