2008 Escalade - rapid clicking no start
Mordechai
Mordechai
I was thinking ground for the starter going thru the fire wall might not be great. sounds like the starter is getting it's ground from that small wire off the terminal to bumper ground, thru the body and back to the starter. instead of from the thick ground from battery directly to block.
There are no ground cables going directly to block on these from what I can tell.
Mordechai
Mordechai
your main battery ground should go here on the passenger side front end of the head, there will be a smaller lead off of the same cable that feeds down to the top of the frame on the passenger side part way up under the radiator support.
I personally also added a large ground from the alternator bracket to the frame on the drivers side
Mine didn't come with that small ground on the head where the battery ground goes to. I'll try to add one to the alternator bracket.
Mordechai
Mordechai
voltage drop to the starter "typically" indicates a bad starter cable, just food for thought but if a ground fixes it then great found the problem.
Voltage drop on the 12v side yes. But I have none. It's only ground side.
j91z28d1
other guys will know better since mine isn't the same as yours. but I'm 99% sure your negative battery cable should run stright to the engine block. where does yours go?
that might explain a lot.
Mordechai
Mordechai
On the gmt900 l92 from the factory from the battery, they have a thick cable going to the head and a thinner cable going behind the front bumper.
Its been like that for the last 312,000 miles with zero issues lol
j91z28d1
I thought you said you didn't have a ground from the battery to the block. Don't mind me I'm lost at what you got going on over there.
Mordechai
Mordechai
Correct. The head and block aren't the same part of an engine. They're connected to each other which is how i'm guessing the starter gets ground.
it's not small the oem ground cable is 4 gauge I believe, the little other wire going the opposing direction is the injector ground I believe, could be wrong.
the one I added to the alternator is 0 gauge
then there is the not pictured lead that goes down along the frame to the front.
on the gmt800's it's all reversed to drivers side and the small frame ground you can reach from under the front bumper
Mordechai
Mordechai
Yeah I was referring to the little one... 2008 doesn't have that.
iche
