2008 Tahoe LTZ. No oil. Added 2 quarts, dipstick still doesn't show anything.
I beg to differ Sir. You can see it clear as day. 0:18-0:22
you are correct, my mistake, no cake for me lol
but... I would guess one of the mounts is shot and caused movement/vibration and caused the bolt to loosen or someone worked on it and didn't check there work. those bolts should not just "come loose"
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
It looks like someone has worked on it. You can see the passenger side bolts have been disturbed too. I would change the mounts and check all the bolts in the area like the axle flanges and the cross member. With it having been low on oil too maybe someone did a pan gasket?
ya I would def be checking torque on everything under there, the rust is kind of scary.....that's a whole problem on it's own.
stevedonato
Change it and if it was me, I would do all of them, but I like to spend other people's money.
Does anybody know why all this stuff does NOT happen to GM pickups from the 90's? I have a 1996 Sierra that never had any of this stuff changed, and after all these years zero oil leaks, and original valve cover gaskets as well? 4.8L v8. Florida truck all it's life.
a lot of it depends on and use and abuse
Davheal66
So I -think- I know where the clunking may be coming from. I got under there, and I can literally push the front hog head up about half an inch. The mount bolts that the differential is attached to have play, so do the bushings where the mount bolts to frame.I have not used 4wd since I got the truck last friday, nor do I plan to ever, this was bought as a work truck, my tools aren't heavy. I'm fine with 2wd. That said, I took it to a mechanic, he wanted to sell me on motor mounts, but this is no motor mount I'm hearing, we agreed they are bad, but not the clunk cause. Then he said the sound is coming from the transfer case and said $2500 to replace. I am willing to replace a transfer case myself, and I will for sure replace the front hog head bushings and tighten mount bolts.
My question is, can I remove the front driveshaft, and drive in 2wd, to see if the clunking persists? If the clunking stopped, perhaps all I need to fix is the bushings/mounts. On the other hand, the mechanic did say that as long as you're in 2wd, there will be no load on the front axle, which makes sense.
I did check transfer case fluid, my finger could not fit in the hole to check fluid level, so I figured I'd add some anyways to see. I was able to fill it with probably 3/4 a quart of dexron6. Rest went on me and the ground. Not sure if it'll take more, I couldn't tell if it was leaking cause it was full, or if it was leftover fluid from the bendy funnel. Put the drain bolt back on. The clunking is still there. Maybe it's not as noticeable? I think I'm saying that because that's what I really wanted to happen. No it still clunks though, either way.
The clunking comes when I'm stopping, abruptly or slowly, about 10-15ft before the actual stop. It also comes when I go from P to D, 6/10 times. Same with reverse to D, maybe 3 or 4/10 times.
Pretty sure it's already in 1st gear when I hear/feel the clunk. Transmission shifts fine, up and down, it's just hard to tell if I'm in 1st when I hear the clunk, the long pipe headers with this engine have quite a rumble. Tbh, it drives/feels like my 67 mercury cougar, if it had power steering. I like that though. I don't want to give up on this truck.
Sorry for the book. I guess my question is, can I rule out if the clunk is caused by the failure of the front differential bushings, by removing the front driveshaft? In 2wd only ofc.
Thank you for every reply, yall are saints
Hello there Doubelieve, I have information good or not. I am tearing out the suspension on my 2005 LT. I bought it in Utah last summer and toured the west for two months. It has been on blocks here in Illinois all winter out of the salt. The rubber bushings are all questionable, I chose to replace. 200k miles and 18 years old, new bushings ALL around, pitman arm, steerbox seals, and fancy paint. The clunking sound from this vehicle I thought was driveshaft related, possibly rear end. When it shifts there can be a MILD clunk, like a u joint. I believe my issue is internal play, and has not worsened. Going to service the transmission eventually. Rear end problems are common with these too, repairs parts are also common.
When bushings are worn or disintrgrating, they usually have corrosion sticking to them. Bad rubber leads to other issues.
Axles are very easy to remove with the tire off the hub. Remove 36mm axle nut, break the tie rod loose, take out a bolt, rotate and repeat 5X, move axle clear and tap from outer hub. With the removal of the front axles, the hubs should not make any noise unless moving, check for unwanted play. A debris cover should be used on the hubs to protect the splines, look at the 2wd bearings available. Disable the 4wd so it does not engage accidentally, check for play, use a supersize channel lock or pipe wrench. I'll take the axles if you'd like?
DBacon
Mid Mich
Is the added exhaust near anything it can touch when the engine moves as you put it in gear?
Warren23
