2011 Tahoe Suspension ?? ZW7
mb311
Been reading on this forum and internets for 2 days straight trying to figure this damn Tahoe out for replacement suspension stuff. What a PITA. First I have 2011 Tahoe LT 4x4. It's the family vehicle, grocery getter. Bought it at GM dealer (certified) with 55K on the odometer and now has 160K.
I thought the suspension was original to vehicle but now I question everything. Positively I have 22755311 (AKA 540-631) rear shocks, and 25978750 springs installed on the vehicle now - I pulled numbers off the current shocks/springs.. These don't appear to match with the ZW7 rpo code though. Can someone confirm?
I'm going through maintenance items, and although no major issues, I have to believe these things are worn out by now. Want to maintain good ride, we rarely tow anything, only occasional dirt road during hunting season.
I want to replace the fronts with a quick coil over assembly if possible - recommendations?
For the rear should I just replace with the same shock? I have always replaced springs with shocks, and at 160K I think I should - recommendations.
Glove box sticker for reference.
THANK YOU!!!
M
mb311
Also not really interested in anything that lifts the vehicle.
Replace both the shocks and the springs.
@915_Tahoe can see your VIN in the photo, and he may be able to provide you with exact part number for both the shocks and springs.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Front Absorbers
LH/RH
20955487 $164.72 each
Front springs
LH/RH
25876851 $188.77 each
Rear Absorber
LH/RH
22755311 $122.18 each
Rear Springs
LH/RH
25978750 Discontinued
Everything Rene wrote is correct.
My rear OE springs were also discontinued. I used the 45H2164/19255624 in place of them. Towed 6,000 pounds the other day without a weight distribution hitch and she didn't sag. My truck is longer than yours and do not know if that makes a difference.
Using your VIN, ACDelco's website shows one other option: 45H0427/19255419
M
mb311
Thanks for confirming.
So ZW7 is not actually the premium smooth ride suspension without the accompanying rpo code (Z55, or G69 I think), at least for the GMT900.
And everything on RockAuto that says excluding the ZW7 would actually be ok to order in my case, since I don't in fact have the smooth ride package.
What a PITA to figure all that out. Sheesh.
wakeboard8787
I have been going down this same rabbit hole and have a Tahoe that has the ZW7 RPO code and no Z55 or G69. I want to order the AC Delco spring/shock combo off Rock Auto that says "Except ZW7". Did you use this shock and spring and did it work?
HAIGDEDNEDNA912
