2013 Yukon/I’m new to car building anything helps
E_Guwapo
I’m looking to build my 2013 Yukon 5.3 into a yuhawk looking to get a cam headers not sure on the injectors since my 5.3 has flex fuel any and all recommendations and ideas are appreciated!!
Trey Hardy
Eastern North Carolina
Flex fuel injectors are plenty big for mid 500s which will take work to get too anyways
Best bang for the buck is port your heads out or have a set of 243s ported out valve job done throw a good top end in it from Texas speed with a 224 cam or the chapacabra or btr truck Norris all these can be ran with a stock converter and make pretty good power gains and sound wicked!
Of course speed engineering Longtubes and catless x pipe with full exhaust will help tremendously along with a custom tune from Hp tuners and a good sealed air intake that should get you where you want to be
If you want more Hp then speed engineering makes a twin turbo kit which a couple buddy’s of mine run and have actually had great luck out of them! They use quality turbos (precision turbos) and parts and are quite cheaper then a supercharger Only thing you would need is a lt4 fuel pump which sadly costs over 1000$ last I checked
Foxy
I would go with the Camshaft swap at least a stage 1 or Chopacabra Camshaft. Make sure you do the DOD/AFM delete also. Get rid of those GM junk lifters. Put a monster tune on it and you'll notice a big difference. If that's not enough for you putting on a whipple or magnuson supercharger would do the trick. It would still be good for towing if you needed to with it.
Marky Dissod
... looking to build my 2013 Yukon 5.3L into a yuhawk ... any and all recommendations and ideas are appreciated!
Since you likely have a 6L80, you'll want to upgrade to 3.73 axle(s) gear(s), cam or not, heads or not.
dropit
