2014 Yukon XL Denali
wsteele
If you look in your owners manual, it will call out the lube spec. I think 75W90 to the GM spec is what they likely call out. I think maybe the Denali has a limited slip rear end, if so, they may also call out a limited slip additive.
You will get lots of opinions about different weights. I always go with what GM says with my truck, seems to work OK.
2003DenaliXL
Think I will go with the 75W90 and this additive:
https://www.autozone.com/greases-an...limited-slip-gear-oil-additive-7-oz/17352_0_0
What type of fluid is recommended for rear differential on my 2014 Yukon Denali.
Is this a good choice?
https://www.autozone.com/greases-an...75w-140-synthetic-gear-oil-1-quart/706574_0_0
TIA.....want something I can P/U locally.
Tony, 75W90 full synthetic is what it calls for. You do not need limited slip additive. What does matter though is the capacity, if you have an AWD Denali, it will take 2.15 quarts and if you have a RWD Denali, it will take more, fill to about a finger nail below the fill hole (15-40mm).
2003DenaliXL
It's AWD Denali......so no benefit to the additive? Is there any harm in using the additive?
This is for the rear........
intheburbs
SE MI
You don't have a limited slip differential, so you don't need the additive.
Foggy
KS
On the RPO sticker in glovebox you can find your options codes
If it has G80 listed, then yes you DO have limited slip rear diff
Most of the synthetics have a limited slip additive built in, so
you don't have to worry too much about it.. But technically you should
add the limited slip additive if you have RPO G80 listed
intheburbs
SE MI
The G80 is not a limited slip. It's a locker. It doesn't have the clutches that have to slip on every turn. So it doesn't need the friction modifier because you won't have any clutch chatter.
The G80 acts like an open differential. But when one wheel slips and the difference in wheel speeds exceeds 100 RPM, it locks. Once traction is restored, it unlocks.
This video illustrates the difference between the G80 and a typical limited slip.
Mech1962
