i would go for supercharger
What a great answer!
I know right... Way to narrow it down and provide some direction or even an answer to the OP’s question. It’s cool though thats one way to get your post count up...
When it comes to power adders for our rigs in the form of boost I personally am pretty torn between the pros and cons of a Twin Turbo set-up and a Whipple/Magnuson supercharger setup. An Armageddon TT kit for example seems to be pretty “bolt-on” for an experienced mechanic likewise with a Magnuson/Whipple set-up. Granted there are more parts with an Armageddon TT kit but I feel the level of difficulty is negligible for either kit.
At the end of the day I think it really depends on how you want to drive your vehicle, where the power is important, and what you want out of it. None of us are buying these size vehicles to put down the fastest 1/4 mile times. I think it’s safe to say most of us are using these rigs for daily driver, family hauling, business commuting, grocery getting duties. Yet if you’re an auto enthusiast chances are you crave power, performance, with mpgs lowest on the list, etc.
Do you want to be fast off the line light to light? Probably supercharger. Depending on turbo set-up you could still brake boost off the line a bit pretty affectively.
Do you want to be rolling down the highway and hang with a stock Vette/high trim Camaro when they roll up? Or merge/pass on the highway like a boss every time? Probably TT
Is efficiency important to you and maybe being able to run around town and stay out of boost and maintain decent mpg? Probably TT
These are just some example considerations there are plenty more. There’s pros and cons to each power adder set-up and only you know how you like to drive and what you want out of your vehicle. With our vehicle platform there will be sacrifices in a lot of areas the question is what are you willing to live with or accept when spending the coin to boost this type of vehicle?
Cheers to adding boost to your truck. Good luck and a smooth installation wish for you. Hope it all goes well. Post up your exact set up and end results once it’s all done. The greatest benefit of forums like these are learning from the experience of others.
