Brake Upgrade Help
Marky Dissod
If you want 17" wheels you'll have to get some off a '19+, or get aftermarket with the '19+ offset and back spacing.
They do still run 17" wheels on the new trucks.
And most of the ones with 18" or larger wheels, still have 17" spare tires.
Which is proof that 18" wheels are not strictly necessary (except maybe on the PPVs?).
Matthew Jeschke
Sahuarita, Arizona
I believe one is for disc/drum brakes and the other is disc/disc brakes.
Interesting thanks.
I got the steel braided hoses installed. Fairly simple job. Other than center hose above rear diff ROYAL PITA. Haven't had much time to test them out. Will post once I have. Discovered my rear brake pads have like 10 miles left on them haha Glad I looked. They're GONE. Will post when everything is working and tested. I did do a short drive but not sure I got all the air out of the lines so cannot say much yet.
buckwild27
Interesting thanks.
If you want to really get a bigger master cylinder piston, get a master cylinder for the 2002, 2500 with 4 wheel disc brakes. You'll have to get adapters for the lines that go into the master cylinder. It works great though. I put one on my 91 sierra years ago.
Fless
Super Moderator
Elev 5,280
@Sam Harris that's awesome! I'm eager to do this now... I noticed one additional "Potential Upgrade" but not sure about master cylinder fitment...
There's two part numbers for the master cylinder. The first is a 1.338in bore:
The second is a "Gold AC Delco Part" with 1.456 in bore:
Wondering which one I have in my truck or how to even tell. Either way curious if it's the smaller one and I'd like to swap in the bigger one would it fit?
One is for vacuum boost, the one with the bigger bore is for hydroboost. Look it up on RockAuto and compare the dimensions of the GM MCs.
Matthew Jeschke
Sahuarita, Arizona
Great tip! I'll keep this in my wishlist!
Matthew Jeschke
Sahuarita, Arizona
This, right here.. I upgraded mine to the GMT900 front calipers (2010), and also installed the Powerstop Z36 kit (carbon / ceramic + slotted / drilled rotors), along with all 5 stainless braided lines from Goodridge. The rears were already the better 2-piston GMT800 brakes, but also installed the same Z36 setup in the rear. This configuration improved my (non-hydroboost) braking measurably. I've avoided several certain accidents, due to having vastly increased stopping performance. (also running factory 2015 Yukon wheels @ 18" on my '03, to fit the rotors)
I went to junkyard today in search of the GMT900 brakes. Spoke with guy there who's like a walking encyclopedia of factory upgrades for GMT800 trucks. He said he highly recommends a brake swap to Cadillac CTSV, XTS, or ATS front brakes. Told me he did it on his setup. It's a factory four piston caliper made by Brembo. Works with factory hoses and he thought should fit 17" snowflake rims but wasn't 100% sure as he has 18". Anybody done this swap? Parts are roughly same cost.
Mirek
