350 engine blown cracked heads
Jedi-GT
My 99 2dr yukon was was getting new top gaskets redone with a replacement delphie injectors (ACDelco)
I started off with engine temperature going banana on me.
ATTACH]
First I had to release the steam off to cool it to start disassembling it for the flush and rebuild.
Went and got a replacement thermostat and a reservoir. All pipes seems in good condition
ATTACH]
ATTACH]
ATTACH]
ATTACH]
Jedi-GT
Jedi-GT
After I got the radiator done
The radiator showed symptoms of gaskets issues
I ended getting gasket kits and a delphie upgraded injectors.
Knowing those kind of engine are known to have cracked cylinder heads so I was prepared for the worst.
ATTACH]
Both heads were cracked
Jedi-GT
Jedi-GT
I was able to get two new OEM heads from GM for about 200 bucks.
Also, I was able to find and LS2 engine.
My question will be ... will it be a direct plug and play for the LS2 engine?
Second option would be upgrading the crank shaft with the stock heads. Does the corvette crank shaft fits? What other option do I have for a stage 2 performance? (Header, exhaust system, spacer, crank shaft, air filter etc)
SunlitComet
OBS Jedi-Do Good
unknown at this time.
going to an ls2 from a vortec obs or tbi is a big change in wiring and components. doable but not plug and play when you make the changes yourself.
DallasTahoe
You got both heads for $200??? Where at? I need a pair, everywhere I've looked they want $325 or more each!
SUBURBIAN
All Chevy
The LS2 is just about the opposite of plug and play.
Why do you want a crankshaft from a corvette?
Jedi-GT
Jedi-GT
I think I was lucky with the price
I grabbed it immidiatly before the error correct it self.
Jedi-GT
Jedi-GT
I read somewhere that the corvette crank would fit the 350 but I've yet found a valid document that supports it
