3800 Using Coolant
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Is there any easy way to completely drain the water out of the block and cooling system on the 3800? I want to put in distilled water not sure if there's a way to get the water out of the block on this?
bigdog9191999
sw michigan
Unfortunately not out of the block, pulling the lower hose is about as good as your gonna get. The radiator should have a drain on the bottom of it.
dawg1
