4 Hi mod help
L
lucasbrackins
How to wire up the 4-HI mod.
Well any more ideas? im lost and have been lol. Tomorrow evening i plan on unplugging the ballasts and plugging in factory bulbs and see if it still does it. Would this method rule out relays or the harnesses?
L
lucasbrackins
if i plug the ballasts directly into the factory harness will that tell me if its the relay harness??
L
lucasbrackins
ImageUploadedByTapatalk1365627217.668299.jpg. Can yall see whats going on?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
and with this setup the lights seem to work mostly alternately? not at the same time correct? if that is the case and your grounds are good you either have low voltage issue which each ballast is reacting differently or something is wrong with the ballast. one other thing to try is to switch the ballast side to side. if that lighted side is acting the same way the ballast is likely not at fault.
---------- Post added at 02:27 PM ---------- Previous post was at 02:24 PM ----------
also could use the diode orientation as well in the drawing. which side of what wire has the diode band on it?
L
lucasbrackins
90% of the time i loose both lows
---------- Post added at 05:30 PM ---------- Previous post was at 05:29 PM ----------
The band is going to the low
---------- Post added at 05:33 PM ---------- Previous post was at 05:30 PM ----------
---------- Post added at 05:37 PM ---------- Previous post was at 05:33 PM ----------
I talked to another HID company and they said to go to a 6amp diode instead of a 3
SuitedSevens
