4 Hi mod help
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you may need to use a slightly higher one with the voltage drop you are getting. but if that fails you are gonna need to rethink your electrical situation here. for the power that supply hot voltage to relays, where is the main line on relays tapped into ?
L
lucasbrackins
How to wire up the 4-HI mod.
If you are talking about the hot wire to the relays it is on the post under the fuse box cover. I am 98% sure that that post is directly connected to the battery
---------- Post added at 06:11 PM ---------- Previous post was at 05:50 PM ----------
More info!!!! I can flip back and forth as quick as i want to within the first minute or so of the headlights being on without problems????
---------- Post added at 06:27 PM ---------- Previous post was at 06:11 PM ----------
Ok so i wrapped a 6amp diode around the wires of the 3amp and i left my highs on for about 5 minutes then flipped back to low and ta da it worked but after about 30 flips i lost a low beam. Normal???
L
lucasbrackins
Ok well i did it because in running out of wire lol
---------- Post added at 07:34 PM ---------- Previous post was at 07:22 PM ----------
I drew the diagram wrong. My diode is in the relay harness right before it goes into the relay for the "trip" wire
L
lucasbrackins
ImageUploadedByTapatalk1365637944.051633.jpg. Corrected
Saucy_Walnuts
