47,000 miles - should I do all or none of these???
Yes, correct.
I think I'm going with the trans/transfer case and see if I can either do the differential myself or find a better price.
But I kinda want the dealer on the hook for warranty-ing the transmission and transfer case.
you can save money doing it yourself, I think about 1/2 of that price (roughly) is labor if you go with oem fluids
TahoeFL2017
TahoeFL2017
Agree. Think I am going to wait a couple months until Florida cools down, then try the differentials myself(it's hurricane/monsoon season here, and 92+ every day, not exactly the environment to be laying on the ground lol). If it's looking like a pain, then I can always hit up the dealer before 50k miles, to get the warranty/repair credit for doing it prior to 50k miles....
wjburken
Eastern Iowa
If you do take on the differentials, might consider investing in a small fluid hand pump. Harbor Freight sells them.
Do it in the morning at sun up or after 5, you can easily do the differentials and transfer case yourself. You can do the transmission fluid exchange yourself, we have some posts around here explaining how it's done. Dealer charges about $175 or so.
TahoeFL2017
TahoeFL2017
Is the transfer case running the same fluid as the trans?
I read somewhere that transmission and transfer case for the front wheels are the same fluid
Excuse my ignorance about this , it's been a while since I've wrenched on anything.....
I don't remember what the fluids are for the differentials in your K2, the transfer case takes Dexron VI. Download a copy of your owner's manual from Chevrolet.
wjburken
Eastern Iowa
Your transfer case takes Dexron VI just like your transmission.
PG01
Up here to the right
Ditto for the change fluids and have cheap insurance. At the minimum I'd do the transmission fluid change (flush and filter). Just because the MFG states a change interval doesn't mean that changing early isn't a benefit. I'm looking at scheduling a transmission fluid change and don't quite have 15K miles on my 2019.
Have you looked at the trans in your ‘19 yet? 10sp in my yuk has No dipstick and says no service until 100k...plus filling it would an issue with no dipstick tube....
Bob2C
Northern VA
Change out all your fluids out to Amsoil Signature. You will easily get 100k miles out of them. Changed all mine at 24k along with trans filter. I’ll probably get rid of the truck before it needs to be done again. I only drive about 10k a year.
Rdr854
Northern VA
What is the severe service schedule? Is a GM maintenance plan worthwhile?
a-reem
