6.6 Gas L8T Engine Swap in 2015 Suburban
L8T BURB
L8T BURB
Kentucky
I would think it would work as recieved. My question is how are you going to work around the PS pump delete? If I were doing it, I would see if a steering rack from the 7-14 would bolt up and then use the power steering. That would make it so the belt could stay as recieved, then just leave the mechanical fan off and use the E-fans.
My thought is that the the p/s reservoir and pulley would be removed from the 6.6 engine and discarded. Likely would then need a custom length belt I suppose since it would no longer route around that pulley.
From that point, since we're planning to utilize my Suburban ECM, the steering gear/linkage from my Suburban would remain in place and work as it did before with no steering disgnostic error messages. I may be way off base here.
Thoughts?
B-train
I guess I need to familiarize myself more with the electric power steering on my 2017. If it hooks up like a normal rack with an intermediate shaft, I don't see why switching to the fluid type would make a difference. The steering wheel just measures rotation I believe. My guess is an electric rack mounts to the same spot as the old hydraulic one.
I'll look tomorrow and see what I can gather between 2008 and 2017
Bigkevschopshop
Northside H-Town
Anyone have insight on whether I would be able to maintain the 6.6 belt driven components? Such as a/c compressor, alternator, and water pump? I would feel better using the 6.6 stuff as opposed to using my 186k mile stuff from my 5.3. The new 6.6 came fully dressed with all belt driven components attached.
Since the motor doesnt have a vac pump on it, and your old 5.3 did, I would suggest doing hydroboost brake booster upgrade and retaining the power steering pump if it will clear the rack thats in there. Just a thought.
The compressor and alternator and waterpump should be clear.
B-train
Or.....will the vacuum pump fit where the PS pump goes? Maybe it will swap over and then you have a plug and play setup.
But, I'm all for just going with real PS and hydroboost brakes as well.
L8T BURB
L8T BURB
Kentucky
My technician is in the process of pulling my old engine and transmission out today! I believe the current plan for the vacuum pump/brakes is to tap into the pcv system for the vacuum needed to the booster. He rattled it off real quick and talked over my head a little lol.
I did google and it seems that most who delete the vacuum pump have had the most success when running a vacuum off of the pcv system. I'm not 100% on the details but he seemed to believe it'd work fine.
Details still to come on the power steering. I will update when I know more! Pics of it in the operating room, lol!!
Bigkevschopshop
Northside H-Town
Yeah the intake vac used to run the brake booster on prior models. I think they went to the vac pump for efficiency reasons maybe who knows... some engineer sitting there decided he needed something to work on.
Look forward to the outcome on this. Giving some of us a good idea for life after AFM! haha. :Good or Bad:
B-train
I believe the vacuum pump was installed to supplement the lack of vacuum in certain rpm ranges where valve overlap it too great to make sufficient engine vacuum. Valve overlap is the new EGR and reduces pumping losses inside an engine for CAFE and MPG evaluations.
RST Dana
OH
Because the big cammed engines didn’t have enough vacuum because their were too busy sucking in air/fuel mixture?
TollKeeper
Brighton, CO
Get a power washer, and some degreaser, and clean that engine bay...
I think you are going to have to stay with hydro steering, unless you are really wanting a dash rewire. I am pretty sure the force sensors, input sensors, and angle sensors, are not there, for a factory E-Steer to work correctly, or at all. In this case, the simplest solution is the one you already have.
Very interested in this thread thou, and waiting and watching with baited breath.
christian_blake_9
