95 tahoe Blend doors
vendo
vendo
ma
yea ...white and ground voltage goes up and down with the dial...
vendo
vendo
ma
ok i put the old acutator back in and it moves,now my question is clockwise movement seems to be the defrost,how far does it move,for some reason i think it doesnt move enough clockwise,is it out of sync when i put it back in the thing is centered and it fits in the slot..1 more test is to see how much it turns while not connected to the heater box..clockwise
vendo
vendo
ma
i see there is a stop going to the defrost side,so it moves as much as it can
east302
Mississippi
Not sure if it will help, but here’s mine at the three main positions. The position indicator dial’s notch tracks between the three marks or lines on the actuator.
vendo
vendo
ma
yea thats what mine looks like..not a ton of air to defrost,i will drive it and check it later,returning acutuator to amazon.. thanks al
east302
Mississippi
If the actuator turns between those marks and the linkages are intact, any diminished air flow is probably a problem with the damper or the top foam seal coming apart in the box and maybe blocking the duct. Without taking it apart, it would be guesswork.
vendo
vendo
ma
looks like a lot of work to take it apart..
vendo
vendo
ma
i only get full floor when i put it on defrost/floor setting,comedy of errors i had,the head i put in didnt move actuator for defrost,so i got one from amazon and it still didnt move,bought new head..still nothing...put old one back and i get it to move..
vendo
vendo
ma
is there any calibration things to do..or its just the way it is..putting it on floor makes it come out vents is screwy..
warndogg
Defrost is I think on upper left. The one in the middle (where the links meet) is I think the floor vent. Upper right is panel.
I think that’s right, lol.
East302 have a question how do you get to this part in the picture? On my 96' the arm on the left keeps popping out up top and I have to crawl under the dash and re attach to get my defrost to work on driver's side after switching modes. Is there any easy way to drop that box?
Tator Tahoe
