98 Yukon Battery/electrical problem
YukeDuke
Grass Valley, CA
I replaced my alternator after it tested bad. Then replaced my battery. At first the gauge showed a good charge. Then after driving with either the headlights, air conditioning, or both, the gauge shows a drain. I have to use the battery tender every night. I replaced the alternator under warranty a second time and the shop says it charges fine. Any suggestions?
Donnie Yukonie
Yates Caretaker
is there a relay for the alty? :think: if so maybe a sticky relay?
Y
YukeDuke
Grass Valley, CA
Ground strap and relay
Not sure about the ground strap. Will check it out tomorrow. Sometimes I see the gauge move towards 14 as if it is charging but it is still on discharge side. Will have to look into relay as well. Thanks for the leads!
retorq
Kingman AZ
Forget the gauge, they are notoriously bad or read low. What does the battery say with a multimeter across it when the engine it running??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
no relay make sure with key on you get batt volts at that 1 wire connector on alt if voltage still vary as measured at alt post, usually a sign of internal damage.
Steven94
