Adding amp, Power wire??
TnTahoe
TN
i have a pac oem-1 that I will sell ya, send pm if interested
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
Alright, well to update this thread a little, i got the subs in w/ a pac, but now im going to amp the door speakers. I have this Schoshe...
Question is, do i have to cut the speaker wires under the cupholders and put them in the input end and then run my own wires from the output on the schoshe to the amp, then of course do the rca's. I dont really want to run wires to the door speakers then to the amp right now, if i did that, im still kinda lost on where to plug this in for the rca's.
Sorry never have kept my stock radio, but i am in this case, since its factory nav.
Which wires are the door speakers? cant find that thread that has them marked and pictures..
thanks,
and tntahoe, thanks but i got this one for free. But if it doesnt work, i'll pm you.
(1000 views, wow must be alot trying to do this same thing)
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
Alright scratch that above, the schoche, how is the oem 1 as luckie stated? or is it this one? PACOEM-GM24 Anyone using it. Searching, it looks like i dont have to cut anything, and can just unplug it and plug in my factory stuff and be back to normal. For when i sell, or whatever. Is that right? I will just have to run speaker wire from the door speakers to the amp and then plug in the oem 1 and be done... If so, TnTahoe, you got pm. that way i can go back if need be and not worry about cut wires.
luckie80
Phoenix, AZ
The way the PAC OEM-1 works is simple. One end plugs into the factory harness on your truck, the other end plugs into the factory stereo, no wires need to be cut at all. The oem adapter is just a jumper between the factory harness and your stereo. The end that is attached to your stereo also provides 4 channel RCA's (2 sets) and the remote turn on lead that all go to your amp. if your intention is to bypass the factory amp and to replace the factory speakers then you will only need to run a seperate set of wires from your amp to the speakers in your car. If you leave the factory leads in place you can return your truck to factory by simply putting the old speakers back in and connecting the old leads from the factory harness. If you have On-Star I would recommend leaving the front tweeters stock so that you can still maintain the on-star capabilities.
And to answer your other question, the one you will need is in fact the pacoem-gm24. That will work in your Tahoe. That is the same one I have in my 04 Yukon XL. it works great. Have the factory radio playing and charging my I-Pod Touch and pushing my Fosgate 15"s.
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
Thanks luckie,
I have been reserching it online all nite, and seems like the better way to go, that way i can return it to stock, by just unpluging and pluggin back in. Just will have to run wires to amp as you stated. Much better than cutting. Im keeping the stock tweeters for now, until i get a real set of speakers. Just want to amp the door speakers for now.
Just thought about this also, since you said ipod, i have the isimple ipod adapter also on my tahoe. WIll this oem gm24 mess with that. Meaning will i have to unplug it to add the oem gm24.
thanks
luckie80
Phoenix, AZ
Thanks luckie,
thanks
You will not have to unplug it if the isimple adapter is plugged into your cd changer slot. The Ipod adapter I have takes the place of a cd changer and has its own connection in the back of the factory stereo. The harness from the pac-oem connects where the factory harness would go. I am not sure how your ipod adapter works but you should be fine because the pac-oem is virtually the same thing as plugging in the factory's wire harness. I will try and post some pics of my "factory" install this week so you can see the ability of customization with a factory look. And I don't even have the Nav unit.
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
Luckie
Yeah pictures would be nice to see how it all goes and what can be done. I would greatly appreciate it. Just whenever you get the time, no rush man.
Appreciate your info and help on this matter..
thanksj
mike
Papawolflopez
