Air cleaner body removal
rjr
I have a 2015 Yukon 5.3. The guidance says that for several operations, including battery or headlamp replacement, the air cleaner housing should be removed. I have no problem removing the top cover or filter. Guidance says that the air cleaner body simply pulls off, but mine has not yielded to considerable pull. I don't want to break it, so haven't tried prying. Am I missing some fastener and does anyone have any suggestions on how to remove it?
THarber
It will pull off, there are 3 rubber '****' that hold it in place. You will not break them.
Tim
Bob2C
Northern VA
As stated it just pulls up held there by rubber. I had to change my battery so it needed to be remove.
STORMIN08
same here, give it a good yank...it will go. the stud holding it is slightly larger of a head then the rubber grommet. lube it before reinstalling an it will remove easily next time
Silveradofan34
