Antifreeze leaking with no overheating
rn4l21
‘01 Tahoe, 207K miles - The low coolant light came on so I let it sit while I ran and got some. Came back to this leak. No check engine light and no overheating. Any ideas what to check first?6772b415e9e556bdc9c880d3563d1e26.jpg
00'BlueSteel
Carolina
Maybe one of the lines from the radiator to the rear hvac unit. The puddle in the photo does look a little far back to be water pump or any fitting up front.
yep it's mostly on the right side which is where the t-connectors are for the heater core and rear heat on the firewall
Coatwolf
Eastern Virginia
Part number for the T’s if u need them. Dorman 800-414 and 800-413. If you need the other part that comes off T it’s gates 28500
R
rn4l21
Checked my heater hose fittings and they’re good. What should I check next? Thanks for the help so far.cda531af392f9fa7b8b106295ba453fe.jpg
A leak that bad is probably a hose, get under there with a flashlight and take a good look sometimes the hose will only leak under pressure, take it for a spin then get under it right away after
Keyflo
