anyone do E-fans on a obs??
Status
Not open for further replies.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
usually probes are placed directly in the radiator fins against the tube. Inrush current could be doing that How about using a slow-blow fuse or delayed trigger circuit breaker made for motors.
sparg93
Expedition Tahoe
NJ
Hummm... And another thing... I keep blowing the main power to the fan fuse... It came with a 25 fuse but im using a 30 fuse... And its still blowing...
QUOTE]
Why gauge wire are you using??
On my Mark VIII, I'm running a 50amp fuse to protect my 60amp relays.
SunlitComet
OBS Jedi-Do Good
Start up(inrush) current may be an issue. If you use current protection that accounts for that then you may have better results assuming wire sizing and other parts are in proper working order though 25 amp seem very low for fan fusing.
Monstar_est87
City of Angeles
The wires from the kit I bought arent as thick but im not 100% on the gauge.... But I have a 30 fuse and 40 relay...
I said the same thing...
Wat gauge wire would u gents suggest..?
gpracer1
Phoenix
Your probe is in the wrong spot, it should be by the upper radiator hose side, not the cap side. Otherwise you are just measuring the already cooled fluid.
Status
hosleyb
