Anyone Tried This Setup: Factory HU as video screen/NavVideo?
Hawgdriver
Have any of you used the NavVideo setup in order to us your factory Nav Unit as your reverse camera video? It works with Touchscreen(GM4) AND Non-Touchscreen Units (GM5)
http://www.navvideo.com/navvideo-models-nv_rgb_gm5.asp
http://www.navvideo.com/downloads/Install_NV_RGB_GM.pdf
If so, or if not, with this setup where would you recommend you wire the wiring connections so the system works when placed in reverse AND with a toggle switch for anytime use? There seems to be a lot of talk with the A-Piller wire and the driver's lower left fuse box (green wire). I am not sure which is best for my intentions.
Thanks for sharing you experiences!
H
Hawgdriver
Absolutely, my '03 has the non-touchscreen version and the newer ones have the touchscreen version.
H
Hawgdriver
dimini,
So you have installed this setup? If so, any lessons learned? Where did you run your power wires for the camera, etc...? How do you like the camera? Would you choose a different camera? Where did you run the camera wire?
Thanks a bunch!
good backup camera,i installed one factory Nav Unit as my reverse camera video,Convenience And Security
carpdizney
Late arrival
I was just getting ready to order this for my 05 denalli and was trying to research it a bit when I came accross your thread which was posted a year ago. I was wondering if you ordered the NV-RGB-GM5 and if so how it was working?
Colton
