Audio, side view cameras, 2nd Battery, Big 3
kbuskill
NE. FL.
@kbuskill , how did you get the wire out of the RVC sensor? Did you have to cut the end off the original, and slide it out? It doesn't look like it "opens". And so I would have to also slide the new wire through before crimping / soldering on the end, correct?
Yes, I had to feed the new bigger wire through before soldering the end on I believe, if my memory serves me. My new wire barely fit through the sensor... lol
Chrismnj
Chrismnj
NJ
Little mod I thought would share with you guys. First of all I heat wires hanging on my dash so never used the 12 v outlets on the lower portion of middle console. Decided to put two push button switch instead, one to disable ABS brakes second to turn off my A pillar gauges.
And here is the spec for push button.
Chrismnj
Chrismnj
NJ
Why turn off gauges on pillar? Stealth mode :)?
Yeah, for whatever reason they are always on only dim with headlights on, it really doesn't bother me but was just trying to find a purpose for the second switch.
Administrator
Why turn off ABS?
Administrator
to fully disable traction control and stabilitrak.
You know you can do that by holding down the traction control button for 5 seconds, right?
Polomatt
