Audio, side view cameras, 2nd Battery, Big 3
Chrismnj
Chrismnj
NJ
Doing this in my work van, not the Hoe. Gonna place the compressor for it under my hood. I'm more of a hands on kind of guy. How do you fuse #30 to the power source? Thx for the help.
Thinking of adding air horn to mine, I already have the compressor.
I have used existing Jcase fuse just made some wires for it, but you can buy a mini fuse holder or mini fuse tap bottom space is for existing fuse and top for your new device
I always remove the crimp connectors and substitute with heat shrink solder sleeve butt splice wire connector
Chrismnj
Chrismnj
NJ
Just open the instructions for switch wiring, Must be a Chinese translation.
Chrismnj
Chrismnj
NJ
Switches are wired in, forgot to mention if relay is used It would need power to the switch and if the switch has a light ground wire will be required as well.
Chrismnj
Chrismnj
NJ
I think I will change to blue rocker switches, not sure what I was thinking with that green.
Chrismnj
Chrismnj
NJ
ok I got another set of the gauges, because of the 4's were not wright on the first, there is some other difference in it too, look at the pic. who would like to have the 1st set?
eb5665
