AWD Yukon non denali?
if you don't have the owners manual, you should be able to find it online, gm puts them up in pdf
petethepug
Michael
SoCal
Had a 17 Expedition rental for 10 days last Mo. Rode like a bouncy house until put in 4wd hi. Someone likely blew the struts on the way from WA to CA as the plates indicated. Is it just me or does the AWD soak up some of the terrain? If it does I’m a AWD junkie.
KLathrop
KLathrop
Not 100% sure but I believe you can lock the center diff. Top button: Full time 4wd with unlocked center diff. Middle button: Hi-range 4wd with locked center diff. Bottom button: Low range 4wd with locked center diff.
This was an optional 4wd system that was offered very briefly on the Tahoe/Yukon/Suburban and Yukon XL.
Unfortunately, finding information on it is extraordinarily difficult because if was a very limited time option and GM didn't publish much about it. I think it was called "stabilitrack" which is very confusing because their traction control system was called "Stabilitrak" (with no "c" before the k at the end.)
BTW here is another thread on the same topic:
https://www.tahoeyukonforum.com/thr...-with-stabilitrack-awd-with-4lo-button.16579/
I've never seen a side-by-side comparison of the AWD system with the AutoTrac 4wd system (the one with the Auto 4wd feature) that is on most of our trucks, but I would imagine there wasn't much of an advantage to the AWD system over AutoTrac which is probably why GM dropped it after 2005 or 2006 and never offered it on any of the GMT-900 or K2XX trucks.
Interesting, I still have a bunch to learn about this truck. Ill try and read up on it in the manual if its in there.
jimweis
Lancaster, PA
My AWD Tahoe suits me fine in PA, the system has three open diffs with no way to lock. It relies on the brakes to be applied on any wheel spinning faster than the others. I'm starting to have some issues with the encoder motor and the inertia sensor now, at its age and miles 180K. The AWD system on mine has always been noisy. I've had both front and rear diffs rebuilt, the noise must be the transfer case.
HiHoeSilver
Away!
Chicago
Looks to me like AWD with a 2 speed transfer case. That top button is traction control on/off. If you push it, do you get a message or light about the stability system being off?
adriver
IF YOU REALLY WANT TO KNOW WHAT YOU GOT (everything, its got):
Here are two GM RPO CODE MASTER LISTS,
https://www.silveradosierra.com/resources/file/3817
https://www.marshu.com/images-websi...codes/gm-firebird-camaro-GM-RPO-car-codes.pdf
You might have got the build sheet included with your vehicle, but probably not. There are several ways to contact GM to have them send you a copy so you know what every option is... Otherwise all your RPO codes (the individual codes that tell every option your vehicle has) is listed in your glovebox.
I spent some time once, went through, and made a list of mine:
AE7 178 P STS M SEAT FRT SPLIT, DRIVER, PASS 911210 E T E A
AU0 747 P LCE R LOCK CONTROL, ENTRY REMOTE ENTRY 970124 E E E A
AU3 750 P LOCK CONTROL SIDE DR, ELEC 910213 E E E A
A31 1072 P WINDOW POWER OPERATED, ALL DOORS 970310 E F E A
B30 2367 P FLC R COVERING FLOOR CARPET 910508 E T E A
B32 2369 P FMF R COVERING FRT FLOOR MATS, AUX 880729 E E E A
B85 2552 P BSM R MOLDING B/S EXTERIOR, BRIGHT 911205 E T E A
C5M 3721 P GVW M GVW RATING 6,100 LBS 980623 E T E A
C60 3771 P HTR M HVAC SYSTEM AIR CONDITIONER FRT, MAN CONTROLS 980126 E E E A
DK7 4282 P CRS R CONSOLE ROOF INTERIOR, CUSTOM 931221 E T E A
D48 5003 P MIR M MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, COLOR. 980422 E 1 E A
EVA 5941 P TEST DVT, EVAP EMISSION REQUIREMENT 980123 E T T A
E62 6365 P BDS M BODY EQUIPMENT STEPSIDE, PUBX 850509 E E E A
FE9 6660 P CER R CERTIFICATION EMISSION, FEDERAL 930430 M E E A
FW1 7300 P RIDE AND HANDLING MANUAL ELECTRONIC CONTROLLED 870629 E 6 E A
GU6 8529 P RAX M AXLE REAR 3.42 RATIO 830101 E E E A
JC5 11768 P BRK M BRAKE VAC POWER, 4 WHL DISC, 7,200 LBS 940211 E T E A
K34 14035 P CRUISE CONTROL AUTOMATIC, ELECTRONIC 840410 E F E A
K68 14147 P GEN M GENERATOR 105 AMP 840710 E 2 E A
LR4 14899 P ENG M ENGINE GAS, 8 CYL, 4.8L, MFI, IRON, GM 960229 E X E A
MG5 15800 P TRN M TRANSMISSION MAN 5 SPD, GETRAG, 84MM, 4.00 1ST, O/D 840430 E T E A
NF2 17057 P EMS M EMISSION SYSTEM FEDERAL, TIER 1 911003 E E E A
NP5 17420 P SWL M STEERING WHEEL LEATHER WRAPPED 830101 E E E A
PDD 19552 P CONTROL SALES ITEM NO. 121 1020 P E E A
PF9 19656 P WHL M WHEEL 16 X 7, ALUMINUM CAST 931221 E T E A
QNF 21210 P TIR M TIRE ALL P235/75R16-106S BW R/PE ST TL ALS 970312 E E E A
SLM 23737 P SPC R SALES PROCESSING STOCK ORDERS 10209 P T T A
UN0 26415 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, CD, AUTO TONE, CLOCK, ETR 980619 E 4 E A
UQ3 26526 P SPR M SPEAKER SYSTEM PERFORMANCE ENHANCED AUDIO 850121 E 1 E A
VB3 27282 P BRR R BUMPER RR STEP, CHROME, IMPACT STRIP 910326 E T E A
VG3 27462 P BRF R BUMPER FRT IMPACT STRIP 910326 E T E A
VXS 28063 P VEHICLE COMPLETE 891114 E T T A
V22 28253 P GRL R GRILLE RADIATOR, CHROME 990216 E E E A
V73 28434 P VCS M VEHICLE STATEMENT USA/CANADA 970508 E E E A
XNF 30282 P FTR M TIRE FRONT P235/75R16-106S BW R/PE ST TL ALS 970314 E E E A
X88 31067 P MAR M MARKET BRAND CHEVROLET 10507 E T E A
YD3 31242 P AXLE (BASE EQUIP) FOR SCHEDULING GVW PLATE 890503 P T T A
YD6 31245 P SPRING RR, BASE EQUIPMENT 970505 P 1 E A
YE9 31284 P CND R CONVENIENCE PKG COMFORT & DECOR LEVEL #3 890523 E T T A
YNF 31578 P RTR M TIRE REAR P235/75R16-106S BW R/PE ST TL ALS 970314 E E E A
ZY1 33292 P CCC R COLOR COMBINATION SOLID 960806 E T E A
Z83 33654 P CHP R CHASSIS PACKAGE SOLID SMOOTH RIDE 910507 E T T A
1SB 35642 P SPP R PACKAGE OPTION 02 880210 M 1 E A
1SZ 35666 P DISCOUNT OPTION PACKAGE 890410 P 1 E A
12D 36004 P TRM M TRIM COMBINATION CLOTH, GRAPHITE (D) (96) 960118 E 3 E A
12I 48556 P CCM M INTERIOR TRIM GRAPHITE II (99) 960111 E T E A
39U 47947 P CCU M PRIMARY COLOR EXTERIOR, INDIGO MET (02) 20419 E T E A
6MS 41923 P FLH M COMPONENT FRT LH COMPUTER SEL SUSP (6MS) 910807 E 1 E A
7MS 43219 P FRH M COMPONENT FRT RH COMPUTER SEL SUSP (7MS) 910820 E 1 E A
From a quick scan it looks like suspension and driveline are F** and G** Codes. Transmission is an M** code, not sure if that might be your transfer case to answer it.
Lukestdenis
