Ben's Tahoe LTZ
soulsea
Bar
Ben, I really like the idea ... it will make for a more subtle chrome accent. :waytogo:
Ben
Ben
PCB, FL
I appreciate it! I just finished the other 3
---------- Post added at 02:02 PM ---------- Previous post was at 01:50 PM ----------
Ben
Ben
PCB, FL
I think it will look good. We will have to see. I need to find a write up on how to change the handles first. I know its a pain.
Ben
Ben
PCB, FL
It took me a long time to change them on my NBS. Just sucks you have to remove the interior door panel. Would rather not do that.
OHSIXX
Milwaukee
Ben
Ben
PCB, FL
Timmy
Brunswick, GA
it's not bad.
1. take off the mirror trim piece
2. remove piece behind door handle on the inside
3. remove piece under the door pull handle
4. remove 3 bolts (front) and 2 bolts (rear). they're 10 mm.
5. pry around the door to pop the clips loose.
look in the holes with the black covers over them and there are 2 10 mm bolts you need to take out. unhook the clip for the door handle and slide the exterior handle to dislodge it.
Loose_Gasket
