Best coil pack replacement?
JubjubW
JubjubW
Wausau, WI
Replaced plugs and wires tonight. I'll take it on the highway tomorrow to see if I get the CEL again. First plug I pulled cracked the ceramic plus they were NGK which some GMs don't like anything but AC Delco
JubjubW
JubjubW
Wausau, WI
Argh. Still have a miss in the higher ranges. Driving me a little nuts here
JubjubW
JubjubW
Wausau, WI
? I haven't touched a coil pack yet. I'm thinking I'm going to replace the o2 sensors when I get a chance.... this will be a long job... spray and soak each one....
I already have all new sensors.
ezdaar
Chat Troll
Redneck central, Aka Houston
use a very tight fitting wrench on the sensors. whack the bajebus out of the wrench end with a BFH and they will pop loose easy peesy.
JubjubW
JubjubW
Wausau, WI
Autumn: oh well all good
Ezdaar: that's my plan. But wisconsin isn't nice to metal. At all
JubjubW
JubjubW
Wausau, WI
Well. Sorry about the long time since update. Started adding the big 3 upgrade. Got one o2 sensor changed. One I have to get some heat for.
Getting constant p0300 and p0430
Rough idle. Not super rough but it's noticeable in the drivers seat.
There is a TSB out there about a ground strap corrosion. Could putting a new ground on stop that? Even if it's positioned in a different spot?
Wish I could zoom a little in my truck when needed. Instead I have to take my bike to do quick things. Rpms above 2500 usually set off those codes. And 90% of the time it's getting on the highway.
Need more time to do things... only get a few nice months a year.
Sent from my SM-G900R6 using Tapatalk
Stevemo70
