Best option for replacing stock shocks
Shock guy
Lots of great ideas on here.....when I try to open the links they didn't work for me....are the bilstein shocks rebuildable?
pizzle
i like the idea of the Moog springs and rancho shocks. How are you guys clearing the error code on the dash when you bypass the autoride system
TheAutumnWind
unplug the battery. remove the autoride relay. wait 10 mins. plug battery back in.
pizzle
so im currently getting "service ride control" because my compressor is burnt out. It burnt out because I have holes in my air shocks. So if i purchase the rancho shocks and the moog springs install those and the do the autoride relay trick your saying I should be good? No "service ride control" and no more autoride system?
TheAutumnWind
That was the same situation i was in. Yes thats how it works.
TheAutumnWind
what shocks and springs do you use if you dont mind me asking
I was running (no longer have the denali) moog 81069 springs (z71/tow package springs) with two coils trimmed off and bilstein 4600's that are stock replacement for a non autoride suv
moog 81071 springs are standard springs and will ride a bit softer and an inch lower or so than the z71 springs.
pizzle
that was just the rear end correct? you trimmed the springs because they made the rear end higher?
pizzle
ezmoney1981
