better mpgs?
blackcoffee
O.G. Black.
I agree with above user, like I stated before. I have 265/75/16 with an agressive mud tread and I get 16mpg. I think with a street tread I could do 18.
stykthyn
panama city florida
my current truck is dodge ram(at least till I can get the tahoe I am looking for) and with street tires inflated to 45psi I avg 14 in town and 21 on the hwy.
put the same size terra grapplers on inflated to their max 35psi and I lose 1.5-2 mpg.
sparg93
Expedition Tahoe
NJ
wow - those are some high inflation rates.
I'm probably naive on this issue, but i've always run @ 32psi...can most tires safely run as high in the mid 40s for our Hoes? Negatives to running that high?
TheBeast99
do you have any mods done? anything like exhaust, CAI, e-fan, etc?
nope, it's still bone stock.
i imagine if i had a performance tune i definitely wouldn't be getting those numbers though, and i'd be right along some of the other dudes here getting 10-12mpg :)
jb2286
Flagstaff, AZ
Sparg, not all tires can be pushed to 40PSI, it really depends on your specific tire, whether it's an LT or a Passenger tire, and the load range.
I got a 95 'hoe that needed a lot of work and I've only just recently begun to start getting her fixed. In browsing all of the available tires I too was surprised to see a light truck tire rated for higher than ~35PSI.
Here is a link to the page I was looking at... http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=55
Hopefully you can find some relatively cheap tires that you can push the pressure up a little bit on. Maybe even try to pick up a used pair of tires on Craigslist just to see if it helps before you spend money on brand new tires.
B
bluebear15
wisconsin
i think i mentioned it before that i was disregarding the tire size. i'm on 285/75/16's and stock is 265 so i'm not that far off to make that much of a noticeable difference. they're bfgoodrich all terrains so not as aggressive as a mud tire. they only have bout 35% tread left so they're not aggressive compared to new either lol and yes i do a lot of hwy driving
TheBeast99
my Yukon came with new tires (Continental brand - wtf?), and they looked a little low this winter, so i put'em up to about 38psi. they say max was 45, so it's all good. they no longer look like they're deflating lol
ibchrisp
Riverside, CA
fuel system upgrade
If you want more mpg try this; I have a 1999 Tahoe 4dr 4wd with 177K miles on it. Driving it for work or to Lake Havasu (from So Cal) towing a boat I always averaged 13-13.5mpg. It ran pretty good, but had a miss (sometimes) when climbing a grade while towing. I replaced Plugs, wires, dist cap & rotor a few times and that seemed to help for a while. But when it recently developed a misfire on cyl #4, I converted the SCFI to MPI and it runs like I never imagined it could. My mpg is up to 18+ without ever a sputter and it feels like it has an additional 100HP ! It's an easy upgrade. The kit is available at most auto parts stores for $300 and you will also need a plenum gasket set. It's a two hour job at most. This is not a half-ass repair in fact GM has a service bulletin suggesting it before replacing even a single injector on the original SCFI.
Regards, Chris P.
LittlePearl13
The Central Coast (SLO county), California.
Regards, Chris P.
This sounds like a pretty good idea... but I don't know what those abbreviations stand for :p
Christian_d
