Okay... Switched ground to side post and same thing.
All the wiggling I've been doing at the battery boils down to those wires running over the computer box and moving it. I rerouted the smaller wire that comes from OEM battery cable and back to frame ground where it was. If I apply pressure to the computer box toward the battery it does the stuff. Let off and it goes back to normal.
Do I have a computer connection issue? Is this common?
Hopefully I'm on to something. Thank you.
You're certainly on to something! Sounds like you've narrowed it down to a bad connection in the harness snapped into the PCM. Try unplugging them then plugging them back in firmly. But, it could be a wire or wires that goes into the connectors that plug into the PCM. You could inspect them to see if any look to be pulled out or just try to push all of them into the plug to ensure they're fully seated. I don't know how much slack there is, but if you could unbolt the PCM and have enough slack in the harness to have it up where you could work with it, you could gently wiggle or tug each wire until you find the one(s) that cause issues when you do.
