Thank you for that explanation “iamdub” (sorry I misspelled your name earlier ), I will attack these 5 areas first, then eliminate the localized issues if still there.
The one I’m worried about is Service 4WD (have heard of people getting stuck in 4WH or 4WL). I’ve cleaned the frame mount grounds. I’ve found the small 4 pin connection on inner drivers fender, cleaned the 4 pin sockets, added dielectric grease and grounded the black negative wire to the firewall ground.
This was good for a week, then display came back. It has to be electrical - when the dash switch for AWD, 2WD, 4WH and 4WL are lite and functional, I can switch back and forth - no problemo!
After the above advice I should check transfer case control module and transfer case motor - plug-in sockets and ground wires.
Your thoughts?
Honestly, I'm not very well-versed on the 4WD systems. The only 4WD vehicle I've ever owned was an XJ and I've never worked on a GM 4WD system other than replacing axles and hubs.
From browsing this forum over the years, I know the module (Might be properly known as "encoder" or "encoder motor") is a somewhat common failure point.
