Blazed's 2011 Tahoe Build
Status
Not open for further replies.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes if your has it its a direct swap over.
Administrator
I remember almost a year ago now I read a post of Robbie's where he listed off a bunch of stuff that'd have to be modified in order to make Esky door panels work in a Hoe/Kon. I don't remember all of the run down now, though.
Blazed
Blazed
Accepting Donations
but if not just extra buttons but not problems
But I was thinking the escalade door panels still have the door switches in them so I could use the memory seat buttons because the switch is flashed for it and the buttons plug into the master switch
---------- Post added at 04:42 PM ---------- Previous post was at 04:40 PM ----------
where?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the panels mounting points are the same. .
Robbie did it?? maybe he can chime in. Does your truck have memory seats now?
Administrator
Not sure. I've PM'd him to jump in if he's got some helpful insight for you. It's been too long and too many posts ago to research the exact post LOL Hopefully he'll jump in here after while when he's got a minute.
Blazed
Blazed
Accepting Donations
the panels mounting points are the same. ill try to find out if the main drivers switch is the same. Ill pop mine off when i can to take a pic of bottom then will know for sure.
the switch is the same Ive put my moms in mine to test those DL3 mirrors I almost kept
Administrator
I don't think he did it but looked into it pretty deeply to find out the feasibility (if I remember right he got his hands on an Esky that was being parted) and found out that it was more effort than what it was really worth.
Blazed
Blazed
Accepting Donations
I currently dont have memory seats
BUT according to all the DL3 mirror options being flashed into the switch and the memory seats being plugged into the switch means to me that I'd have memory seat while using that door panel and that master switch.
but i really dont care about memory seats because i dont even have the 12 way power seats
THE YETI
Director of Operations
South FL
Will escalade door panels fit a tahoe
Yes. But if you have heated seats you're sol since the escalade door handles don't have heated seat buttons.
You are much better off swapping a Denali door panel. Same look but direct swap.
Administrator
Thank you for jumping in, sir :hands: I knew there was something different about them along those lines :Handshake:
Status
jawizzlerizz
